"An all new AF system consisting of 29 pts, as follows:
Most are x-type, centre cluster is high precision for f/4 or faster, all are x-type to f/5.6 and centre cluster allows AF for f/8. Yes AF at more than one point for f/8.
Specs should be:
FF with 16.4MP, Improved AA filter, 7fps for 21 RAW, jpg only limited by card size, enhanced digic IIIA, Improved WB sensor, WideGamut RGB support, since DSLRs can capture colours outside AdobeRGB, 14 bit
ISO 100-3200 standard 50, 6400 via CF, real gaskets around all buttons and doors and an o-ring built-into lens mount, 3" 1MP LCD, with wide colour gamut and protective coating, -/+ 3EV exposure scale
2.5% spot meter, 2, 5, 10 or 20s self timer
Wireless flash transmitter built in, 97% VF coverage with 0.78x magnification, 22mm eyepoint, 3, 5 or 7 bracket shots.
MLU button - Akustyk! To musi być fake, nie? ;)
Live view with AF available like Nikon, 29 pt AF system as described above
AF can use colour and distance information, Joystick selection option for AF points, 47 zone matrix metering, Three setting highlight tone, adjustment (similar to Fuji), voice annotation
800g, 2300mAh Li Ion battery - 1200 RAW shots,
BG-E5W - Wifi grip, with vertical controls, second battery, sealing, more curvaceous and integrated design, - czyli jak EOS 3?
No built-in flash
$3199 - czyli 10kPLN? ;)
New goodies also announced at same time:
ETTL III, new 600 EX (GN 60), 280 (GN 28 ) EX flash and MT-34 EX (wireless)
17-40 f/4L II improved at all FL and designed for improved corner performance and centre sharpness, spectra coatings. Still 77mm since it's f/4."
