dpreview, dyxum
0. name: A-700
Yes it is from Alpha-7
1. sensor: 12MP 1:1.5 CMOS
2. AF sensor: 11 point. Center dual-Cross. new upgraded AF sensor from Alpha-7(film body)
TTL phase-detection system , CCD line sensors(Metering area 11 points)
0 EV to +18EV(at ISO 100 equivalent)
AF illuminator. He said it worked perfectly on complete darkness!!
3. viewfinder:
bright 95% 0.9x magnification with 50mm lens at infinity -1 diopter
4. Noise: Same noise level as Canon 1D mark3 on ISO 6400
ISO 100-3200(ext 6400),Auto ISO 200-800
5. shutter speed: 30sec ~ 1/8000 + bulb
X-flash 1/200 with SSS, 1/250 without SSS
shutter lag smaller than film body alpha/dynax/maxxum-7
shutter noise reduced. similar to canon 30D?
6. rear LCD: 3" LCD 640X480x3(RGB) = 921600 pixels
NO LIVE VIEW!!!
7. Grip sensor revived
Significant upgrade on DRO and SSS
You may shoot toward the sun and WYSIWYG!
8. 16-105 F3.5-5.6 New kit LENS. quality great!
image quality: 18-70 old kit < new kit lens < 16-80 Carl Zeiss
9. Continuous Shots 5 Fps
10. Metering
Metering Cell:40-segment honeycomb-pattern SPC
Metering range:0EV to 20EV (at ISO 100 with F1.4 lens)
(+2EV to 20EV with spot metering)
11. battery
Rechargeable battery pack NP-FM500H
Thanks
