http://www.fredmiranda.com/forum/topic/818787
Ciekawa informacja, że wreszcie jest cichy. W 40d tryb seryjny płoszy zwierzynę w promieniu 50 metrów...
Nie wiem - badań nie robiłem ale znów tak dużo cichszy od np. 30D na moje ucho nie jest. Odgłos jest raczej inny i to może mieć wpływ.
Odnośnie dźwięku migawki: http://blog.planet5d.com/jw6
" The autofocus module felt snappy in our short experience with the camera, but what really got us hooked was the sound of the shutter. Canon told us the firm actually did a survey with other photographers to find out which kind of shutter sound they prefer, and the one produced by the EOS 7D was meticulously crafted as a result. "... hmmmm:)
http://www.canonrumors.com/canon-eos-7d-mini-review/
The 7D would be a great compliment to the 5D Mark II if you want increased responsiveness, snappy AI Servo autofocus and the big frame rate increase. If you bought the 5D Mark II because you wanted the best image quality you could afford, then the 7D may disappoint.
Wszystko w tym temacie.
8 Frames Per Second
The camera is capable of 8 frames per second bursts. I do want to note that there are situations you won’t get the full 8fps. The following is from the manual of the 7D (page 93 USA/Canada).
- When the battery level is low, the continuous shooting speed will be slightly slower.
- In the AI Servo AF mode, the continuous shooting speed may become slightly slower depending on the subject and lens used.
- In low-light areas or indoors, the continuous shooting speed may become slower even if a fast shutter speed is set.
From Canon Tech Support in regards to the slowing of frame rate
The slowdown of the frame rate is because of Canon’s new metering system. Frame rate is sacrificed in favor of metering accuracy.
Workaround?
If you use exposure lock, the camera will ignore the above and shoot at the desired 8fps.
thanks to Dan for the research.
http://galleries.stevemelvin.com/7D_40D_noise_test/
