Dzieki! :)
Temat wałkowany na Adobe widzę, bez efektów, choć jeden z bardziej popularnych feature requestów (60 gwiazdek):
Lightroom: Colour coding folders and collections to simplify navigation & cataloging
- - - Updated - - -
Swoją droga, szukając informacji o kolorowaniu folderów, znalazłem interesujący temat o problemach z wydajnością z LR4. Nie wiem czy ktoś ma z tym problemy, ale pracownik Adobe opisuje w tym temacie sztuczki jak sobie z tym poradzić w dość banalny sposób:
http://feedback.photoshop.com/photos...s_are_resolved
Proszę o info jak zmienić w LR nazwy plików?
450D zrobił mi już IMG_9999 i numeruje od nowa czyli IMG_0001 z tym,że w katalogu kolejnym czyli 101-0001 itd . LR widzi tylko "IMG_0001" więc zdjęcia zaczęły mi się*powtarzać,jak to zmienić w LR?
Wątek jest dosyć długi. Masz na myśli to?:
Hello all,
We do acknowledge that there have been a performance hit for truely "some" users, though that doesn't comfort the users that are seeing the performance hit that they are seeing, and professionals that do potentially lose time (which = money) due to the decrease in performance.
Now that there is acknowledgement of the issue, we still don't have a resolution, nor know exactly what is causing it on the multitude of systems that are seeing it.
Thanks to those that are delving in deeper to try to discover what the cause is, and hopefully we can all look for a solution, since it is happening on not all systems, but some.
I wanted to call attention to a potential solution that was given by another user on another forum after a chat with adobe support. I've paraphrased some of the steps and cleaned them up a bit so they can be digestible, but would be curious to hear of other's results after having tried these steps.
A fair amount of users are running in windows, and these steps are windows-centric, if you're a mac guru, perhaps you can divine how to perform similar steps on the mac platform.
Here is the chat log and troubleshooting steps.
Please try them out, and let us know if you see any improvement with any of these steps.
William is the tech, and Jojo the end user with performance trouble.
Chat log:
William: I understand that you're experiencing performance issue. Am I correct?
Jojo: Oh yes
Rename Preference folder
Please close all windows
Click the Start button.
Type %appdata% in the search box and press Enter.
Double click on Adobe folder.
Rename the "Lightroom" folder to "OldLightroom".
Clear Temp files
Click on Start button.
Type %temp% and press Enter.
It will open Temp folder.
Empty the files and folders inside it.
Results chat:
Jojo: ok done. it still has files that could not be deleted for Win Explorer and Google Chrome (the browser I use)
William: Okay.
William: Launch Lightroom and check if you're getting the same issue.
Jojo: that seems to have sped it up significant;y
William: Perfect.
William: Please double check if that works fine now.
Jojo: Much faster, but all of my presets are gone
Jojo: Export presets, etc
Rename old preference folder back so LR sees it.
Quit Lightroom.
Rename the "Lightroom" preference folder to "2-OldLightroom".
Rename the "OldLightroom" and rename it to "Lightroom".
After that open Preferences folder inside it.
Rename the file "Lightroom 4 Preferences.agprefs" and to "OldLightroom 4 Preferences.agprefs".
Launch Lightroom and test the performance
Results 2 chat:
Jojo: Oh yes, that's working well!
William: Perfect.
Jojo: Much better!
William: You can start working with the product smoothly now.
William: Great.
Jojo: Hey, are they fixing this in a release? I know a lot of photographers who are VERY upset about this performance issue. I was ready to change back to LR3
William: Corrupt preference may cause Lightroom to work slow.
William: We renamed the preference file and it is working fine.
End Chat log
Another user had mentioned that they "renamed the Lightroom 3 Preferences.agprefs to Old_Lightroom 3 Preferences.agprefs and now it works a lot quicker."
Those are at least a couple things to try that shouldn't take but a few minutes.
Report back with any change in LR 4.1 behavior
Thanks!
Tak. Ja nie próbowałem, ale ja nie mam problemów akurat.
Chciałbym zapytać Was o kwestię Lightroom vs DPP, jak to wygląda na dzień dzisiejszy w kwestii kolorów na starcie w RAW. Z tego co widziałem, to jednak profil Aodbe Standard daje najbardziej zbliżony obrazek do DPP, czy Wasze spostrzeżenia też takie są?
Mam pytanko związane z wykorzystaniem pamięci RAM przez LR.
Otóż mam Windows 7 (64 bit) i LR 4.0 i w kompie zainstalowane 8GB RAMu.
Moje pytanie brzmi:
Jak sprawdzić, czy mój LR podczas pracy maksymalnie wykorzystuje możliwości komputera (a więc korzysta z całej dostępnej pamięci RAM)?
Jeśli okaże się, że nie to drugie pytanie: "jak go do tego przekonać" ;-) czyli czy można jakoś wymusić, aby korzystał z jak największej ilości dostępnej pamięci - aby wydajność była jak najlepsza...
Ctrl+Shift+Esc, zakładka Procesy, proces Lightroom.exe.
Program bierze tyle pamięci, ile potrzebuje. Nie wymaga dodatkowych środków perswazji.
- - - Updated - - -
Adobe Standard to taki ujednolicony schemat kolorów. Jak chcesz mieć kolory podobne do tych z DPP, to wybierasz profile Camera XXXX (Standard, Portrait, Landscape, etc). Ja sam lubię Camera Standard - daje dość dobry kontrast i przyjemne barwy. Czasem korzystam z Camera Neutral jeśli potrzebuję mieć zdjęcie z "płaskim" kontrastem (np. żeby mieć większe pole popisu do wyciągania detali z cieni/świateł).
Mógłby ktoś zaprezentować fotkę z dpp i lightrooma i zobaczymy jakie są różnice, ja teraz nie mogę, na pewno z lightrooma fotki są za czerwone.
Tutaj przykład http://artoftheimage.blogspot.com/20...canon-dpp.html
Robi ktoś z Was projekty fotoalbumów w LR 4?
