bylem w sklepie. Niestety wystawienie aparatu oficjalnie w cenniku na wystawie sklepowej nie pociagnal za soba swojej obecnosci. Aparat bedzie spodziewany z polowa przyszlego miesiaca czyli wrzesnia. Mowa o 40D
Tak nawiasem, to z white paper do 1 Ds MkIII (strony 25 i 26) wynika, że w DPP 3.2 zostanie wprowadzona funkcja Lens Aberration Correction. Oczywiścei informacje o obiektywach są tylko dla szkieł Canona...
There are 4 factors that this function can correct:
1) Peripheral illumination:
Corrects peripheral light, which declines as one moves away from the center of the image, by increasing brightness at the image periphery so that rightness is uniform over the entire image
2) Distortion:
Corrects images where shape relationships are disrupted so that they appear as they should
3) Chromatic aberration:
Corrects color fringing that arises around the image periphery
4) Color blur:
Corrects the blue and red color blurring that can occur at the edges of very bright areas in images
Niestety aby w pełni wykorzystać tą funkcję będzie trzeba mieć nowszą puszkę...
Aż tak źle nie jest :):
Depending on the EOS Digital camera on which the lens is mounted, there are 2 modesof correction using DPP ver.3.2. In the latest models released in 2007 (EOS-1Ds Mark III,EOS 40D and EOS-1D Mark III), the lens ID and the focal length and distance information are recorded as supplementary information in photographed RAW images. As a result, these cameras meet all the requirements for aberration correction. To use aberration correction on these 3 models, simply check the boxes for the factors to be corrected in
the [Lens aberration correction] window.
On the EOS-1D Mark II N, EOS-1Ds Mark II, EOS-1D Mark II, EOS-1Ds, EOS-1D, EOS 5D, EOS 30D and EOS Digital Rebel XTi/400D DIGITAL, the lens ID and focal length are recorded as supplementary information in photographed RAW images, but the distance information is not recorded. On these cameras, when one checks the boxes in the [Lens aberration correction] window for the factors to be corrected in photographed RAW
images, aberration is corrected on the assumption that the distance is set to infinity.
To moze w DPP 8.0 beda juz suwaczki do cieni i highlights :)
