Odp: Nowa wersja darktable
Zbliża się wydanie nowej stabilnej wersji 1.4 darktable.
Na razie można popróboważ Release Candidate : Darktable 1.4rc1
Opis zmian z witryny projektu:
darktable now integrates a lua engine that allows writing scripts to make it easier to use with other image processing software. These scripts can be run when a particular event takes place (for example when a new image is imported) or when a particular keyboard shortcut is used. There are very few scripts available at this point but we expect the community to provide some more during the next release cycle.
darktable now include several kinds of drawn masks: brush, circle, ellipse, path and gradients
exporting in WebP format
serious speed enhancements of lighttable when using large collections
focus detection on lighttable
local cached copies of images for offline files
a few new blend mode like "HSV lightness", "HSV color", "Lab lightness" and "Lab color"
new modules "contrast brightness saturation", "color balance" and "color mapping" which replaces the now deprecated "color transfer" module
new histogram mode "waveform"
added a setting to automatically collapse modules to only have a single one expanded
better user experience for bauhaus sliders: the popup now has a blinking cursor to make possible text entry more discoverable
the text entry for bauhaus sliders and vimkeys' ":set" command can now evaluate mathematical expressions
many bug fixes and small improvements
a tool for measuring basecurves from a sample image
updated usermanual
darktable now requires Gtk+ in version >= 2.24, Glib in version >= 2.30
Już jest do pobrania nowa wersja Darktable 1.4
released darktable 1.4 | darktable
Wreszcie oficjalne maski:
masks | darktable
oraz ciekawostka - wykrywanie i oznaczanie obszarów ostrości
Śledząc poczynania deweloperów darktable zauważyłem, że pracują ostatnio nad algorytmem usuwania bandingu w Canonach.
Jeden transferuje z MatLaba jakąś nową akademicką teorię, inny zauważa, że na brzegach matrycy są rzędy pikseli w pionie i poziomie, które nie są naświetlane i próbuje je użyć do oszacowania rozkładu bandingu aby go lepiej zniwelować. Jednym słowem jak im to wypali to będzie niezła bomba.
A wersja pod Windows kiedyś będzie?
Nie chce mi się po raz kolejny stawiać Łubudubu... :-)
Merde, zainstaluj inne distro np. Mint ;)
Dzisiaj kolejny raz powalczę z instalacją Darktable w wersji 1.4 :)
Już ściagam obraz .dmg na maka. Zobaczymy jak to działa. Na ubuntu też spróbóję:)
OK, więc program odpalilem. Podoba mi się stylistyka nawiązująca do lightrooma, ale mimo wszystko widać, że jest to opensource:)
Wg. mnie nie ma porównania do Bibble Pro/ Aftershot Pro - które to są naprawde profesionalnymi programami na wszystkie trzy zacne systemy operacyjne:)
Uzywałem Bibble Pro do obrobienia tysięcy zdjęć i cały workflow działał wyśmienicie pod Linuxem (Ubuntu).
Darktable ma masę opcji, dużo suwaków, ale ciężko się w nim nawiguje co strasznie komplikuje pracę.
W lightroom np. wszystko jest tam gdzie być powinno i obróbka zdjęć w tym programie odbywa się bardzo płynnie.
Mimo wszystko miło widzieć, że na froncie programów do RAWów na Linuxie coś się dzieje.
Jako ciekawostkę dodam, że mam w OSX ustawiony język polski jako język interfejsu i Darktable po instalacji był od razu całkowicie spolszczony:)
W międzyczasie pojawiły się nowe aktualizacje darktable (1.4.1 i 1.4.2) , w których poza zwykłymi poprawkami
dodano/zmodyfikowano obsługę następujących aparatów:
Sony A77V enhanced color matrix
Nikon D5100 updated white balance presets
Nikon 1 V2 noise profile (and by extension J3/AW1)
Nikon 1 J1 noise profile (and by extension V1/J2/S1)
Pentax K3 noise profile
experimental support for Panasonic DMC-LF1 (we still need samples for the nonstandard aspect ratios)
experimental support for SONY DSC-RX100M2
experimental support for SONY NEX-3N
Experimental support for Nikon D5300
Experimental support for Nikon D3300
Experimental support for Samsung NX1100
Experimental support for Samsung NX30
Very experimental support for Olympus E-M10
New white balance presets for:Nikon D610,Olympus E-PL5,Olympus E-PM2
Merde
Wreszcie zaczyna się pojawiać i to od razu w wersji 2.3 choć dopiero testowej:
darktable for Windows | darktable
