Recenzja Ricoh GXR z modułami 28mm i 50mm w wykonaniu Steve Huff.
Okazuje się (wg rencenzji) że to dziwactwo się sprawdza i jest całkiem, całkiem...
http://www.stevehuffphoto.com/2010/1...-50mm-modules/
choćby fragment:
"Only if you are wanting a camera that delivers fantastic results as a “system”. If you want a 28mm lens that can shoot in low light at 2.5 and give super color, detail, tonality and high ISO performance and also happens to have fast AF and pleasant Bokeh with a sensor perfectly mated to it for optimum results then yea, this is a killer setup. I was thinking and the GXR with the 28 module is not only faster than a Leica X1 in the AF department but it also has a little bit of a faster lens, focuses closer, and has equal or better high ISO performance. It is also more customizable and comes in at half the price of an X1. "
Pomysł o tyle ciekawy, ze bez problemu można sobie wyobrazić moduł który posiada mocowanie do dowolnego systemu,
